OBD2 port and tuning issues
Old Jul 25, 2011 | 09:07 PM
dewd87's Avatar
Default OBD2 port and tuning issues
Hi, I recently got all the bugs out of my 5.3 swap in a regal, so I decided to get it tuned and dynoed.
Well when he hooked the hp tuners up to the port nothing was picked up and I've used a scanner on it before and it worked.
So was seeing if you anybody could tell me what I wired wrong.
It has the 2 grounds on pin 5 and 6, one feed from the computer on pin 2, and the 12v battery on pin 15.
Any help is appreciated.
Old Jul 25, 2011 | 09:31 PM
Rick Speed's Avatar
maybe you used the wrong serial data off the pcm. One is purple and thats the one you need to run to pin 2 the other is tan and is not needed.
Old Jul 26, 2011 | 04:47 PM
dewd87's Avatar
I did check and it is a purple wire hooked up to pin 2. Could I have screwed up a ground?
Old Jul 26, 2011 | 04:51 PM
Snapps's Avatar
Have you made sure your fuses are all good, I had the same problem only to find that my fuse was bad..
Old Jul 27, 2011 | 06:21 AM
psiconversion's Avatar
LS1Tech Sponsor
What is the application (year/make/model) of engine?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jul 27, 2011 | 07:10 AM
Jones'n's Avatar
Isn't pin 16 supposed to be the battery power?
Old Jul 27, 2011 | 12:39 PM
LS1Tech Sponsor
That is correct, pin 16 should be switched power. Computer feed should be from pin 58 on blue PCM Connector. Assuming this is not an E38 setup.
Jon
PSI
__________________
Ebay Store
Old Jul 28, 2011 | 04:49 AM
LS1MCSS's Avatar
Jon
PSI
Pin 16 should be battery power, not ignition.
Old Aug 2, 2011 | 03:56 PM
dewd87's Avatar
ok messed with my 12v on pin 16 and it is working properly.
