LSX in '93 Silverado
Old Jul 26, 2011 | 08:09 PM
amclives's Avatar
Default LSX in '93 Silverado
I had a motor go bad in my truck. I am going to do a LSX swap in it with standalone engine management and use the 700r4. I am going to get the torque convertor from Bowtie Overdrives. Which motor should i get for the cable throttle or can I change it on the DBW motors.
Old Jul 26, 2011 | 09:35 PM
pdsq98gt's Avatar
It would be easier in my opinion to use a 4l60e instead of the 700r4. You'll have to somehow rig up the tv cable to get the 700r4 to shift right. Good luck doing that with a DBW setup. Other than that it should be a rather easy swap.
Old Jul 27, 2011 | 06:17 AM
psiconversion's Avatar
LS1Tech Sponsor
I agree with 98GT with regards to TV cable mounting becoming an issue, especially with DBW. I believe TCI makes a kit that elminates the TV cable, but at that point, unless you have a built 700R4 why not just go 4L60E.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jul 27, 2011 | 06:28 PM
amclives's Avatar
I want to use the 700R4 because it was just recently rebuilt like 40K on it maybe not even that. I want to do a Cable Throttle but I didnt know if I bought a motor with BDW if I could swap it to Cable easily
Old Aug 4, 2011 | 09:19 PM
amclives's Avatar
Ok I checked my receipts for the rebuild and looked up some things on my truck it actually has a 4l60-E. How would i control the shifting if i got a DBW motor? or would the old ecm control it via speed sensor?
