Spectre Tank Help Please!
Old Jul 27, 2011 | 09:55 AM
s.hembree's Avatar
Default Spectre Tank Help Please!
Using the GM34EFI tank in a 70 Chevelle and unsure on the weatherpack connector which wire is for the pump and which is for the sending unit. One wire is gray and the other is purple, I know the other is obviously the ground. The tank didn't come with instructions, and I would rather not drop it back down to check if I can avoid it.
Thanks in advance!
Old Jul 27, 2011 | 10:54 AM
74novacustom's Avatar
im sure this will get answered soon, but when i get home today i will crawl under mine and let you know, i was just under there last night.
Do you have an OHM Meter?
Old Jul 27, 2011 | 02:03 PM
Blue67LS2's Avatar
Gray is the 12volt supply to the pump.
Old Jul 27, 2011 | 03:03 PM
s.hembree's Avatar
Excellent, thanks guys!
Old Aug 1, 2011 | 10:19 PM
flywheel's Avatar
Good luck with your tank, mine is a piece of sh$t....car dies going around a right hand corner when below 1/2 tank.....going to change mine out....
Rick
