S-10 potential project question.............
Old Aug 2, 2011 | 01:36 PM
ad53030's Avatar
Default S-10 potential project question.............
I know this is not typical but I am needing some opinions....
Looking for an S10 for my next project and I found a good candidate but it's got a freakin aftermarket sun/moonroof installed. It seems pretty clean and actually looks fairly factory. No leaks, wind noise. Looking for opinions as to whether I should just keep looking or is the roof not that big of a deal...
I need a daily driver badly so that is a factor but I am needing some input.
Thanks.
Old Aug 2, 2011 | 02:07 PM
the_merv's Avatar
Veteran: Air Force
How much power you plan on making?
Old Aug 2, 2011 | 02:31 PM
ad53030's Avatar
Nothing crazy. 6.0 & T56. Maybe 450-500. How bad do these trucks flex? Cutting the roof like that must take a toll on strength....
Old Aug 2, 2011 | 06:21 PM
Dleep79's Avatar
The S10 is not a unibody vehicle. It is on a full frame and the body of the truck provides very little structal support as it is just bolted on with four 1/2" bolts thru rubber bushings. I wouldnt let the roof sway you if it looks good and doesnt leak. I have a 98 S10 myself that I have been wanting to swap badly. Had a LS1 sitting in the garage that was destined to go in, but finances said otherwise and i had to let it go. I am still hopefull i can make it happen though.
Old Aug 2, 2011 | 06:58 PM
MeanYellowZ's Avatar
^^^^ yes
