1998-2002 Fuel tank fitting
Old Aug 2, 2011 | 08:46 PM
Julius's Avatar
Question 1998-2002 Fuel tank fitting
This might be an old easy to answer question but i need to make sure. Does a fuel tank off of a 1998-2002 camaro, trans am fit a 1997 camaro? Almost done with the conversion, help please
Old Aug 3, 2011 | 12:20 AM
the_merv's Avatar
Veteran: Air Force
1998 will be a direct fit, 1999-02 are different. If it's steel, it'll work.
Old Aug 3, 2011 | 03:28 PM
Julius's Avatar
Thumbs up Cool, Thanks
This is good because im converting my car from an lt1 to an ls3. So just for kicks. the pump is gonna be compatible right? I would also have to switch the fuel lines too right? Took on the conversion without knowing much and now im paying for it. Appreciate the help
