flywheel and spacer
Old Aug 3, 2011 | 12:36 AM
Beeterolds's Avatar
Default flywheel and spacer
HI guys, i just bought a 02 5.3 Tahoe engine for my cutlass.. It does not come with a flexplate.. I would like to use my Grand National th2004r behind this engine and from what i understand you need to use a special spacer between the plate and the crank hub.. my question is do they sell an aftermarket plate that already has the spacer built into it? Or will i have to resort to the obvious, hunt down a spacer and used flywheel? also is there a specific flexplate i need to use for my application? Thanks guys!
Old Aug 3, 2011 | 01:12 AM
the_merv's Avatar
4L80E Flexplate & Spacer setup..you might have to elongate the holes on the Flexplate.
Old Aug 3, 2011 | 01:33 AM
Beeterolds's Avatar
thanks man i appreciate the input
Old Aug 3, 2011 | 08:05 PM
S10xGN's Avatar
I have that combo in my Maverick. Search around here, I believe the relevant parts have been combined into a package. When I did mine, I had to piece-meal it together...
