Help 4l60e problem!!!
Old Aug 22, 2011 | 10:44 PM
ls1nova71's Avatar
Default Help 4l60e problem!!!
I posted this in the transmission section, but thought maybe somebody in this section may have some insight. https://ls1tech.com/forums/automatic...dtc-p0785.html
Thanks, Eric
Old Aug 23, 2011 | 06:02 AM
oldgoat69's Avatar
That is the 2-3 upshift solenoid. I just went through a similar bout. I also had P0740. Turned out to be the stop light switch was incorrect, not applying 12 volt signal. Seems like others have simply replaced the solenoid when that is the only issue. Seems straight forward enough.
Old Aug 23, 2011 | 05:48 PM
lt5's Avatar
lt5
Here's a diagram showing the 3-2 Solenoid.
Old Aug 23, 2011 | 10:55 PM
ls1nova71's Avatar
Thanks man! That looks like what I was needing!
Old Aug 24, 2011 | 12:13 AM
gofastwclass's Avatar
Good luck E.
