Oil Level in LS1 Pan
Old Aug 24, 2011 | 04:26 PM
Andy1's Avatar
Default Oil Level in LS1 Pan
Does anyone know where the oil level is in an LS1 pan when it's full? The level sensor I assume is placed at a level below that, to sense a low condition.
Andy1
Old Aug 24, 2011 | 08:49 PM
the_merv's Avatar
Veteran: Air Force
I put 6 quarts in them..fill the filter with part of one and the rest in the Engine..been doing it with years without a problem.
Old Aug 24, 2011 | 10:27 PM
Andy1's Avatar
Maybe my question was too vague. If I had the pan off the car and filled it with the right amount of oil (say 5 1/2 qt), how high in the pan would the oil level be........1/2" above the sensor? 1" above the sensor? Or how far below the block mounting surface, etc? I'm thinking someone may know so I don't have to estimate it by using the dip stick.
Thanks,
Andy1
Old Aug 25, 2011 | 01:58 AM
01ssreda4's Avatar
Somebody had a picture of a stock pan holding close to 7-8 quarts as it got to the bottom of the windage tray. Mind you this was sitting still and driving would likely throw the oil around just a tad.
Old Aug 25, 2011 | 09:14 AM
G-Body's Avatar
sawzall wielding director
From what I have seen, the oil level varies depending on if its a f-body, vette, or truck pan. I measured the length that the truck and f-body dipsticks stick down below the block before and it was different. Unfortunately I don`t have a f-body dipstick laying around right now so I can`t measure what the oil level in the pan would be.
