turbo 5.3 s10 build
Old Oct 23, 2012 | 08:40 PM
  #361
lsxtreme17268's Avatar
nice build man ! what size pipe did you use to match up to the turbo flange ? Im doing a pretty similar build , might have to pick your rain a bit
Old Oct 24, 2012 | 11:30 AM
  #362
T76s10's Avatar
Thanks. I used a 2.5" merge from mandrelbends.com but i seen people just hammer a 2.5" piper into a square to fit into the flange
Old Aug 23, 2013 | 01:23 PM
  #363
Ron_Stoppable's Avatar
Thumbs down
what sizes were you BOV and wastegate with this 76mm setup. Im running a rear mount on3 76mm on my 98 5.3 swapped noma..
Old Aug 23, 2013 | 10:40 PM
  #364
T76s10's Avatar
its a turbonetics duo 35 bov and i was running an on3 44mm wastegate. on my new setup im using the same bov and two 38mm wastegates
Old Nov 10, 2013 | 09:17 PM
  #365
T76s10's Avatar
thread updated
Old Jan 1, 2017 | 07:56 PM
  #366
1980Regal's Avatar
Default What year 8.8 to get for the rear swap?
What year 8.8 to get for the swap? Out of what vehicle
Old Jan 2, 2017 | 07:55 PM
  #367
rpturbo's Avatar
He hasn't logged in, for over a year, going on 2. Generally speaking, guys pull Explorer rear ends for a S10 swap. Your stuck running specific wheels though, unless you narrow, and center up the rear.
Old Jan 3, 2017 | 09:06 AM
  #368
ss454327's Avatar
I pulled mine from a late '90s 4x4. Camaro offset wheels will work but you will have to redrill for GM axles or use Mustang wheels. I drilled mine but wish I could go back and just buy Mustang wheels...drilling is a PITA.
