issues with LS2 in SVO
Old Aug 29, 2011 | 11:51 AM
SloSVO's Avatar
Default issues with LS2 in SVO
Hey fellas, We dropped the LS into the SVO last night.. ran into a issue we weren't ready for.. the Hummer H3 alpha pan is hitting the rack.. the car has a D&D racing tubular K and we are using 2002 4.6 Motor mounts.. the alpha pan seems pretty short.. but is the f body pan that much shorter/thinner in the front?....... in the oil pan guide we have as a sticky its hard to tell.. the f body pan seems to have a bit of a hump about 4 inches form the front.. it looks like the pan or rack needs to be like 1.5" shorter..??? Since people have made this swap with stock K member we are a bit stumped..
Old Aug 29, 2011 | 05:12 PM
SloSVO's Avatar
so we pulled the oil pan off and the windage tray and pick up tube still hit the rack.. the only thing i can think of is that the rack bosses are higher than a stock k member.. as of now the idea is to cut off the rack mounts and reweld them lower on the K members main tube..
Old Aug 29, 2011 | 05:18 PM
PlatnumStatuz's Avatar
Nice, svo are cool. I had a '85
Old Aug 29, 2011 | 05:20 PM
wg871's Avatar
Post some pics of your project! Or do you have a build thread on another forum you could link me to?
Old Aug 29, 2011 | 06:37 PM
Old Geezer's Avatar
"as of now the idea is to cut off the rack mounts and reweld them lower on the K members main tube.."
Careful doing that. You will be altering the bump steer by moving the tie rods down...
Old Sep 5, 2011 | 06:51 PM
FASTFATBOY's Avatar
Correct it with a bumpsteer kit, I did this on my LT1 car, pan hit the rack.
