Small Power steering question
Old Aug 30, 2011 | 12:10 AM
Dillon93dillon's Avatar
Default Small Power steering question
Im Near the end of swapping my 2000 5.3l into my 79 chevy 4x4 3/4 ton truck, with a few little odds and ends, like exhaust, power steering, drivelines, and some final wiring and fuel line hanging and looming.
But my question here is about the power steering, the silverado 5.3l power steering pump that i have mounted to my motor, looks just like the original for the sb350, but the sb350 pump has sae fittings im assuming? and with the ls motors its all metric... so are the power steering fittings also?
is there a fitting i need to buy or make new lines to run my original lines to this ls pump?
thanks
Old Aug 30, 2011 | 12:24 AM
gofastwclass's Avatar
I have seen this solved three different ways...
Solution 1: You could actually take the fitting from the back of the SBC pump and put it on the reservoir for the Gen III truck pump (if it's the metal tank type) - problem solved.
2: You could have a custom line made if it is the plastic reservoir type or the factory line won't fit or reach.
3: Someone makes a metric to standard fitting for the gearbox side, but I can't remember where I saw it.
Old Aug 30, 2011 | 12:35 AM
well what i am wondering is if the ls power steering pump is metric fittings?
its the metal style pump and resivor combo like a regular small block chevy pump
the fitting can be removed from the back of the reservoir?
Old Aug 30, 2011 | 02:50 AM
garys 68's Avatar
The high pressure fitting on the back of the power steering pump can be unscrewed and swapped.
Or you can use the metric hose, cut the end off that goes to the box, put on an inverted flair fitting and double flair it.
Or theres a company (Lee?) that makes an insert to allow you to mix fittings.
Or you can get metric/inverted flair to JIC adapters Speedway motors) and make your own hose.
Old Aug 30, 2011 | 02:52 AM
chuckd71's Avatar
Or you can get a new power steering box.
Old Aug 30, 2011 | 11:13 AM
74novacustom's Avatar
Just go to your local Speed shop or call summit/jegs, tell them what you have, they will get you the fittings and hose you need and you will be on your way. you will have -6AN high pressure side hose.
Or like said before, just replace the adapter inside the back of the pump with your old one. I believe that still works.
Old Aug 30, 2011 | 05:42 PM
Thanks everyone. I didn't know about the fitting coming off on the back. I just swapped them out. Works great
