Dual tensioners?
Old Mar 5, 2004 | 02:55 PM
ezzzzzzz's Avatar
Default Dual tensioners?
I keep reading about belts being thrown off due to weak tensioners or stretched belts. I'm relocating my alternator to high passenger side and made a triangular bracket that sits where the old alternator bracket was located. It is drilled for a stock tensioner to replace the idler pulley. My choices are to lathe away the ribs of the stock tensioner pulley (leaving only the outer lips), fit a idler pulley in place of the tensioner pulley or machine a custom pulley (with lips). Along with that tensioner, I'd use another stock tensioner just below the alternator like TTI or QMP does. That would provide adequate belt tension I figure. There may or may not be room to work the lower tensioner for the turbo guys but those needing frame or PS box clearance could benefit from this setup. What do you think?
Old Mar 5, 2004 | 07:14 PM
John B's Avatar
Moderator
Use an LT1 tensioner and save the work!
