Fuel system question
Old Sep 5, 2011 | 12:49 PM
occhevelle's Avatar
Default Fuel system question
http://www.summitracing.com/parts/RUS-639210/
So I'm doing my fuel system and was hoping to use the stock 3/8 fuel line and connect to braided line in the engine bay using this fitting. Do I need to flare the line using these?
Old Sep 5, 2011 | 01:08 PM
garys 68's Avatar
How old and corroded is your stock fuel line?
The compression fittings/o rings need a pretty clean tube on the outside for a seal. I would double flair and use an SEA OR JIC fitting.
Old Sep 5, 2011 | 05:12 PM
Pop N Wood's Avatar
I used compression fittings like that with my carburated swap. No flaring. They crimp a ferrule onto the hardline that becomes pretty permanent.
You need to make sure the fitting is rated for EFI pressures. Most of those fittings are only rated to something like 50 psi.
Old Sep 5, 2011 | 08:23 PM
S10xGN's Avatar
Correct! And those particular fittings are NOT rated for EFI pressure. You'll need to find a steel or stainless steel fitting like those from from Parker-Hannefin...
