LS 82 malibu wagon..do i need this?
Old Sep 19, 2011 | 10:48 PM
topstring's Avatar
Default LS 82 malibu wagon..do i need this?
I just purchased an 07 4.8 auto computer,harness etc..I will be swapping manifolds..do I HAVE to have o2 sensors to run this engine? What about the tow/haul option on the trans? Is that just something the computer guys will take off?
Old Sep 19, 2011 | 11:49 PM
G-Body's Avatar
sawzall wielding director
You don`t NEED the front O`2s but I would keep them. Without them you would end up running in open loop and that gives up some of the part throttle fuel economy and other benefits of EFI. You can ditch the rear O`2s as those are only there for emissions diagnostics and have no use if you do not have to maintain emissions compliance for your swap.
The tow haul mode can be tuned out by a tuner, but why would you want to? With the addition of 1 wire and a momentary button it allows you to have 2 different transmission calibrations. You can have it set with one that has factory shift points/firmness and one thats a performance with higher shift points and a firm shift, etc.
Old Sep 19, 2011 | 11:52 PM
topstring's Avatar
Well im fairly new to the swap..and the place im buying the engine only comes with the computer and harness..not sure what else and i have spent hours on end reading but hadnt came across those two topics.If i dont get the wires for the tow option..is that something the harness guys add?
Old Sep 19, 2011 | 11:53 PM
roninsonic's Avatar
If you delete the front O2's and run in open loop all the time, your gas mileage is going to suck. BIG time.
Old Sep 22, 2011 | 11:22 PM
topstring's Avatar
OK i found out from Speartech that 07 up new body truck cannot save the tow'haul for my car...07 up that runs through the body module,so they can't delete it.
Old Sep 23, 2011 | 01:12 AM
the_merv's Avatar
Veteran: Air Force
I'm sure you can wire around it..
Old Sep 23, 2011 | 07:25 AM
psiconversion's Avatar
LS1Tech Sponsor
Is the 07 you have an early 24x engine or a late 58x engine?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
