Need advice new to LS1
Old Sep 22, 2011 | 09:11 PM
jonnican57's Avatar
Default Need advice new to LS1
Need help! '96 Camaro 3.8 4A complete, 2001 Z28 6M completed (body totaled) want to swap entire mechanicals into '96. Big question: wiring - gauges I have the mechanics figured out. Will '96 Z rad work?
Old Sep 22, 2011 | 09:37 PM
the_merv's Avatar
Veteran: Air Force
The LT1 Radiator is the best..everything will bolt up from the LS1 Car..the 96 Gauges will work, the V8 Cluster will be more accurate. Wiring can be accomplished..you will have to add some circuits in the Fuse Box.
Here is a thread with some good info..
https://ls1tech.com/forums/conversio...to-95-z28.html
