BMW M3 E36 LS1 swap
Broke a Vband clamp, so had to get a new one before driving.
Going to schedule a tune at CMS for next week.
Also ordered a BER ported LS3 intake manifold.
Stock LS3 Longblock with 24X reluctor swap
EPS 222/230 .596/.600 lift, 114 plus 1 LSA Cam
Unported LS3 Intake Manifold
LS3 injectors
PTM 92MM Cable Throttle
85MM Maf
4inch Intake
1 3/4 New Age Hotrods swap headers
Dual 2.5 inch custom exhaust with Dinan muffler with Magnaflow Cats
ASP Pulley
LS1 Wiring harness and ECM
T56 Transmission
Stock M3 LSD with swapped 3.91 gears
Pretty Happy with the numbers with basically a stock LS3 with small cam. It idles like stock.
Dyno Video
http://www.youtube.com/watch?v=C2W4h...layer_embedded
New Emblems
I know nash sells alot of swap parts and a few other companies do aswell. Just wondering what fits best.
The throttle cable catches my eye, where did you purchase that from ?
Is there any chance you can pass emissions? Even if you put some cats on it and had it tested as a 6cyl
Also Does the car have a engine light of any kind ?
In CT if you have cats and no engine light your good to go.
What is the advantage of getting an M car over a regular 330ci if you are going to pull the motor and tranny?
There's plenty of LSx wiring information in the Engine Conversions section of BimmerForums.
This is a good thread to reference if you're considering an engine swap.
And this is one of several wiring threads worth reading.
Tipsy
Tipsy
Ok thanks. I was just curious, I've seen these wiring harnesses that they're selling for $800 that uses the stock bmw connector.
