where to look up LS engine block and head numbers?
Old Oct 13, 2011 | 11:55 AM
goldhunter_2's Avatar
Default where to look up LS engine block and head numbers?
the question is where to look up LS engine block and head numbers? I just would like to know exactly what I Have.
Here is the story , I am not looking for any super build right now just a super low budget ls engine in a c3 corvette (stop laughing) I bought a 1980 vet for $500 and traded aircraft parts for a LS engine that was on a airboat. I don't know if this was a "stock" ls motor or a "custom built" airboat motor by a reputable LS engine builder specializing in High low end torque ls motors for airboats I know there was history between the owner and builder just not sure how this motor plays into it.
I have looked online and searched here, I did find some posts but nothing with these numbers . It would be nice for future reference to know if there is a site or chart to search LS casting numbers and stamped numbers, but here are the numbers and locations for what I did found on my LS engine if you have a link to a reference chart or can ID any of these numbers please do.
*Block looking form pulleys back on the rear outside of block by where tranny bolts up I found this casting number "1W51140084"
*Right Head cast top corner "806"
*Right head stamped on the exhaust surface face under the 806 and above the sensor location was stamped "11/24/97"
*Right head center outside surface has a dotted stamped number of "1 08 1 05 32 K 22 7"
*Left Head cast top corner "806"
*Left head stamped on the exhaust surface face under the 806 and above the sensor location was stamped "11/24/97"
*Left head center outside surface has a dotted stamped number of "2 03 2 12 23 K 20 7"
Here's a couple pictures of my LS engine (hope the LS doesn't get to intimidated sitting next to a lighter 346cubic inch four cylinder)
Old Oct 13, 2011 | 02:38 PM
Project GatTagO's Avatar
That looks like a 97 or 98 Corvette LS1. It is definitely a Corvette C5 pan and the electronic throttle body are dead give a ways. Also the valve covers have perimeter bolts, which I believe were 97-98 only items.
Andrew
Old Oct 13, 2011 | 02:51 PM
thanks Andrew I figured if I posted pictures to then someone would have a idea what it mite be form either the numbers or the pictures.
"97-98 C5 corvette LS1" just that info will help a bunch when I am calling the junk yards looking for the ac compressor and alt bracket , apparently the local salvage yards can't look up any parts unless you tell them the year and car it came out of
Old Oct 13, 2011 | 03:59 PM
stealth71's Avatar
Any 97-2002 accessories should work. I'm pretty sure they didn't change them until the C6/LS2.
Old Oct 13, 2011 | 07:25 PM
The C6 accessories are nearly identical to the C5. There are part number differences in various components, but the bracketry and general layout is identical.
Andrew
Old Oct 13, 2011 | 07:28 PM
This link should help:
https://ls1tech.com/forums/conversio...oem-parts.html
The accessory brackets and hardware are not very expensive brand new. GM Performance also has a complete kit that is reasonably priced that includes all brackets, alternator, PS pump, AC, and all pulleys and hardware.
Andrew
