no fuel pump
the fuel pump isn't priming. the dash lights come on, the clock works, taillights work, but the fuel pump wont prime. it's a 97 240sx with a 2000 SS ls1.
i ran the battery directly to the fuel pump to see if i had connected the wires incorrectly, but when i swapped my jumper wires to the leads of the fuel pump plug, the pump still primed, so it was pumping backwards, hah? are they supposed to do that? it's a walbro pump.
i'd appreciate any help, because i have no idea how to diagnose this problem.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
the fuel pump cover is on, i'm just running two wires from a battery to the two prongs on top of the fuel pump cover. if i put the positive to the right prong, and the negative to the left prong, the pump kicks on. the thing that confuses me is that if i reverse that, the pump still kicks on. positive to left prong, and negative to right prong. gaw, i'm sure i'm making no sense. sorry.
similar to this picture. http://i55.photobucket.com/albums/g1...X/IMGP0399.jpg
i'm pretty sure i'm using this configuration.
http://img129.imageshack.us/img129/9745/inletwn8.jpg
the inside fitting(orange) goes back INTO the tank, and the outside fitting is being fed the fuel.
i wish i knew whether i wired it correctly, haha. i guess i could always remove my crimp job and swap the wires and see if that works? but see the description of the wires above and see if i made an educated guess.
you're talking about the reverse polarity mod, right? i've called sikky twice and they said i shouldn't have to do anything.
