LS3 swap in my 99 Corvette
Old Oct 17, 2011 | 05:30 PM
1_bad94Camaro's Avatar
Default LS3 swap in my 99 Corvette
I hope this is in the right place. I'm swapping the LS1 in my vette for an ls1. Gen III to Gen IV. I know the LS3 has no knock sensors so thats no big deal. i'm needing a map sensor extension, cam sensor extension, and everything else I need for the swap.
Thanks in advance
Steven.
Old Oct 17, 2011 | 05:34 PM
-TheBandit-'s Avatar
Last I checked the LS3 (and all Gen IVs) has knock sensors. They are just in the side of the block instead of the valley. Also the crank has a 58x reluctor instead of a 24x. Are you wanting to run the LS3 on the LS1 PCM? I'm sure this has been done before, but it will likely take a little more than just wire extending.
Old Oct 17, 2011 | 05:42 PM
I thought the same thing. a friend of mine swapped an LS3 in his 94 camaro with no knock sensors. I understand the 58x and 24x relcutor wheels. I've seen a converter box so I can run the 58x wheel on my LS1 PCM. Yes I would be running the LS3 on my LS1 PCM.
What all would I need to finish this up? i've got all the parts ordered to finish the engine and also ordered the converter.
Old Oct 17, 2011 | 06:53 PM
Tainted's Avatar
Search is your friend and the big sticky with ls3 into ghost as well
Old Oct 17, 2011 | 06:55 PM
Tainted's Avatar
Into fbody. Hate god damn auto correct on phones
