Corvette LS2 fuel injectors
Engine is a LQ4/LQ9 with 317 aluminum heads from a 2002 Cadillac Escalade.
Intake is a LS2 from a 2005 Corvette with stock injectors and 90mm throttle body from Eldelbrock
Harness will be modified and built to be a standalone. I will probably end up buying an LS1 harness for the retrofit
Cam is stock from an Escalade but I plan to upgrade to atleast a Zo6 cam or bigger.
All the above is planned to go into a 1971 Nova with my built 200r4 Transmission
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Two issue is about the Truck front accessories with the Car intake. just research on what you need to do there..
other issue is getting the 200R4 TV cable setup and working.
keep us posted on your project.
BC
