F-cooling fan question
Thanks John
eroc, it doesnt matter if you put the relay on the 12v side or ground side, the pin locations are still important as DC has a direction. For your application, you need battery 12v to the pin B side and the relay 30 side is pin A, then ground the relay from pin 87
