Dynamax headers scrape in lowered first gens!
Old Oct 29, 2011 | 10:34 PM
rp0029's Avatar
Default Dynamax headers scrape in lowered first gens!
So I installed GW L16 1 1/2" lowering rear springs in my 68 camaro because the JCW springs for some reason had the car looking like a joe dirt special - too much rake. I have Hotchkiss lowering springs in the front, I want to say 2".
Problem: The dynatech headers I installed in the LQ4 will get scraped more than a fisherman's knuckle. They were about 2 1/2" off the ground, with the new rear springs, like 1 - 1 1/2".
I love the stance, hate the scrape. I'm putting some half inch spring spacers in the front (which will raise the front an inch), maybe that will help a tad.
So let this be a lesson to you all: dynamax headers hang like 3 1/2" below the subframe of a first gen. If your car is lowered, be prepared to driver VERRRY slow over speed bumps.
I know Tony had this problem.
I might replace the headers, but then I will have clearance problems with exhaust hitting the x-member. We'll see how the spacers work.
Last edited by rp0029; Oct 30, 2011 at 05:11 AM. Reason: I'm a moron and called "dynatech" headers "dynamax" headers.
Old Oct 29, 2011 | 11:27 PM
Jimbo1367's Avatar
that seams to be Dynamaxs' glaring problem. The bright side is you have a pair of headers to model new ones from. Just a few inches shorter.
Old Oct 30, 2011 | 01:14 AM
futureuser's Avatar
You mean dynatechs, right? Mine scrape some too.
Old Oct 30, 2011 | 02:06 AM
wayne33's Avatar
does anyone have some headers that dont scrape without spending thousands? my car just clears my 18" rims..
Old Oct 30, 2011 | 05:13 AM
rp0029's Avatar
1) If I did this, the 2.5" exhaust would hit my PATC transmission x-member. I think there is about an inch or two of clearance there.
2) Could I have an exhaust shop shorten these headers by cutting them while in the car? I don't really want to pull the headers.
Old Oct 30, 2011 | 05:14 AM
rp0029's Avatar
Yes. I'm an idiot.
Old Oct 30, 2011 | 08:23 AM
SS69LS1's Avatar
This is just an idea, and may not help a whole lot- can you shim the trans tail shaft up at all? This should bring the headers up just a bit. You may have to re-do the pipes at the collectors. I am going to try these headers on my 68 firebird with hotchkis springs. Any pics of how far they hang down?
Scott
Old Oct 30, 2011 | 08:45 AM
rp0029's Avatar
Scott
Shimming would mess with my drive line angles. Transmission is down two degrees right now which is perfect. I really think I'm just going to swap for mid lengths. Only problem is going to be my crossmember. I'm going to take more pictures today.
Old Oct 30, 2011 | 08:48 AM
rp0029's Avatar
Also, if I do decide to go to mids, would you be interested in purchasing my headers? I'll knock $100 off what I paid for them. The additional advantage to this is that it takes like 6 weeks to get them from dynatech. I'll know next weekend for sure whether I'm keeping these headers, so let me know if you're interested.
Old Oct 30, 2011 | 09:22 AM
futureuser's Avatar
Mine, could come up a couple of inches and still clear the patc crossmember.
Old Oct 30, 2011 | 09:38 AM
rp0029's Avatar
Future is your car lowered?
Old Oct 30, 2011 | 10:16 AM
Jimbo1367's Avatar
Yup. I though it didn't sound correct. LOL.
Old Oct 30, 2011 | 10:47 AM
bmf5150's Avatar
I got stainless works headers I bought from pro touring store,they don't hang that low!they are a little tight on the power steering but they worked out good!i paid around $800
Old Oct 30, 2011 | 11:19 AM
69 Ghost's Avatar
Be careful with the SW headers. I have the forward position mounts and bought a set they hit on the steering box and the idler arm. I took them off only to notice a hole in one of the welds at the flange. I called them up and offered to help them fix up their header so they would fit on basically any conversion. They said it would cost me $3k for a set of custom headers. Needless to say I went with some Kooks TBSS headers for about the same price. The quality difference is not even close. Kooks uses thick welds and makes a very nice header.
Attached Thumbnails Dynamax headers scrape in lowered first gens!-stainlessworks0016.jpg   Dynamax headers scrape in lowered first gens!-stainlessworks0037.jpg   Dynamax headers scrape in lowered first gens!-stainlessworks0042.jpg
Old Oct 30, 2011 | 11:35 AM
scatillac's Avatar
Default Gen 1 Dynatech Header Clearance
The lowest part (header flange) of my Dynatechs is just a smudge over 2 1/4" below the bottom of the subframe, which is about the same (or even a bit less) than some of the SBC Gen 1 cars around here.
So far, no scrapes but it's probably not as low as yours as you can see in this link.. https://ls1tech.com/forums/chevrolet...071-lives.html
I believe that I had said the motor mounts were Energy Suspension, but they are actually Prothane SBC standard height mounts.
Old Oct 30, 2011 | 02:15 PM
futureuser's Avatar
About 3 inches from stock. I have gotten used to the occasional scrape and the headers are holding up well. I don't actually regret buying them, given my other options at the moment.
Old Oct 30, 2011 | 06:09 PM
rp0029's Avatar
I have hotchkiss 2" front drop springs (part no 19830012) and just installed the global west L16 1 1/5" lowering rear springs. Edelbrock IAS shocks all around. I must have the wrong mounts/frame stands or something, because look at this crap:
I'm going to try raising the front 1" with spacers, and if I still scrape a lot I am going to swap out some mid length headers or something. Before the lowering rear springs (think joe dirt) the exhaust was a bit low, but this is just too crazy.
Old Oct 30, 2011 | 06:19 PM
SS69LS1's Avatar
Man thats horrible. Maybe I'll be going with some mid-lengths.... I went with stainless works on my 69, but this firebird build is on a tight budget. Scott
Old Oct 30, 2011 | 07:03 PM
bmf5150's Avatar
Wow that's crazy low!
Old Oct 30, 2011 | 08:17 PM
rp0029's Avatar
So what headers would you guys go for? I really want long tubes, do any tuck nicely?
