ls PCM location in fox mustang????
Old Oct 30, 2011 | 09:13 PM
THE-CHAD's Avatar
Default ls PCM location in fox mustang????
Hey there guys I am in the process of getting my swap going but I still have a couple questions are you guys using truck PCM's or car PCM's I got an 03 tahoe
PCM and been told that I will have to mount it in the engine bay of my fox in which I think will look very tacky so is this true if not where do you fox swap guys mount yours?
Thanks in advance
Old Oct 30, 2011 | 09:26 PM
LSCustoms's Avatar
I dont have a fox body mustang, but I can tell you, you dont have to mount the pcm in the engine compartment... it just depends on how much soldering and extending you want to do... you can put it wherever you like... where would you like to put it?
in my el co, im putting it inside the truck, behind the ac delete plate...
Old Oct 30, 2011 | 09:35 PM
THE-CHAD's Avatar
well I have no heater box behind the the dash so that is what I was shooting for and I was going to run like a rewired harness psi or ls1harness.com not to set on that yet but you get the picture
Old Oct 30, 2011 | 09:44 PM
LSCustoms's Avatar
the guy at lt1swap.com has good stuff too and good price, but cool!
Old Oct 30, 2011 | 11:03 PM
spacemanspif's Avatar
Pull all of the loom and tape off your harness, cut the wires after marking them on both sides of the cut. Run the harness on the engine in the cleanest way you see fit combining everything into a few major clusters before the big clump runs into the car. Decide where you want to mount the computer. Then the only thing left to do is cut to length and solder and heat-shrink everything back together.
Truck harnesses seem to have a lot more extra wire than the car ones.
Old Oct 31, 2011 | 12:19 AM
THE-CHAD's Avatar
Thanks guys I do have the truck harness from the same truck I got the PCM from cable throttle also but not to sure what I need to keep and what I can cut away that is why I was just going to buy the harness
Old Oct 31, 2011 | 01:06 PM
Chrome_Rust's Avatar
I am doing mine inside the fenderwell where the air box was. In our cars there is the hole where the rear brake lines run into the engine bay, perfect place for a harness to route through. I am also going to wire tuck the entire engine bay, and that looked to be the cleanest place to put it. I am going to be using the painless harness with the extra 4' length.
Old Oct 31, 2011 | 01:12 PM
LSCustoms's Avatar
before you spend any money check this out (4 parts)...
[youtube]tITS_uOXZrU[/youtube]
go to lt1swap.com for the pinouts and try it yourself, or send it to him and he will mod it for you for a fraction of the cost... it seemed intimidating, until I jump into it, was super easy....
Old Nov 1, 2011 | 06:17 AM
zipster's Avatar
My computer is where the stock one sat. I extended the harness. I used lt1swap.com for info and schematics. If you are not afraid of soldering wires, just do it.
Old Nov 1, 2011 | 10:20 AM
groundczero's Avatar
I have an 85 LX and since the battery got relocated to the trunk, I just mounted the computer there.
Old Nov 1, 2011 | 03:23 PM
boostnut's Avatar
I'm not familiar with the 93's, was it in the pass. side kick panel? That's where it was in my 95 & I hope to put the new one there. Looks like its gonna be a tight fit.
Old Nov 1, 2011 | 08:36 PM
zipster's Avatar
boostnut,
yes its in the passenger side kick panel. It fits, but it was tight.
Old Nov 1, 2011 | 08:45 PM
Bowtiedford's Avatar
mine is behind my glove box. I have a/c and heat.
Old Nov 2, 2011 | 02:22 AM
itsslow98's Avatar
How did you manage that? Mine is currently sitting on the floorboard. I cant for the life of me figure out where to the damn computer lol.
Old Nov 2, 2011 | 06:47 AM
it sits on top of the box, you do have to remove the a/c tube that provides air for the far right side vent. I can access it with out pulling the dash. I drop my glove box and look inside and there it is. The diagnostic port is mounted to the glove box. Maybe later tonight I can get a pic of it.
Old Nov 3, 2011 | 04:52 AM
itsslow98's Avatar
I would appreciate that bowtie, I dotn have a/c just heat so I can sacrifice a vent if need be. Damn LS computers are too big lol.
Old Nov 3, 2011 | 07:22 AM
sdetweil's Avatar
right.. I just did mine, and it really wasn't that bad.. take out all the wires you don't need (rear o2, egr, a/c), stretch the harness out so the passenger side is straight, then extend the drivers side..
this put the computer back just over 5 ft from the back of the manifold.
one trick.. the truck injector harness on the drivers side comes in from the front, and you'll want it from the back.. so just swap the 4 wires at the computer so that they lay out the other way..
I cut the 4 injector signal lines (not the power) and positioned the harness, then patched the 4 wires.. then extended the coil circuit the same way.
the alternator and coolant sensor circuits need the same extension.
as I am going back to cable throttle from drive by wire, I had to add the 7 wires for the TPS and IAC circuits, but you have all the wires you removed to do that..
I reused existing wire for everything, only supplying heat shrink and solder.
I use a little butane flame torch for soldering and heat shrink.
I used the lt1swap.com info, watch out for the TPS wiring.. I had them reversed and it thought the pedal was floored..
sam
Old Nov 3, 2011 | 07:49 AM
sorry got home late last night, will do it later today.
Old Nov 3, 2011 | 05:49 PM
this is the connector in the glove box
I forgot I took the blend door off for more room. So its like having your air on the max setting. Fan speed still works.
Old Nov 3, 2011 | 11:26 PM
itsslow98's Avatar
Thanks I really appreciate that. Ill see if I can do the same.
