Crank position sensor wires
Old Oct 31, 2011 | 01:01 PM
luke_sedz's Avatar
Default Crank position sensor wires
Hi. I have a 2000 camaro ss Ls1 that I'm trying to put into an s2000 and have no spark. I've just found I have no wires going to my crank position sensor. Does anyone know if I can hardware this in and of so where do the wires need to go to? ECM pin etc?
1 - dark blue/white
2 - black / yellow
3 - light green.
Thanks a lot
Old Oct 31, 2011 | 03:31 PM
LS1MCSS's Avatar
Here is the schematic. If you need the connector, just search online for LS1 harness connectors. Don't try to hard wire it. Fix it the right way.
Old Oct 31, 2011 | 03:34 PM
luke_sedz's Avatar
Cheers for that. I found the wires in the end.
Old Oct 31, 2011 | 08:30 PM
FatfreeGTO's Avatar
The car will still start, run, drive etc without the crank position sensor plugged in FYI. Or at least that was the case with my 6.0l
Old Nov 1, 2011 | 03:48 AM
luke_sedz's Avatar
On the ls1 there was no spark until I plugged it in then I got a spark and the engine ran.
Cheers
