Advice needed for 350z ls1 project
Another question, does ARP provide a bolt kit for nearly everything on an ls1? Its buying all the accessories, nuts, bolts and misc. things associated with the engine that scares me of starting out with just a short block.
Thanks Guys
https://www.texas-speed.com/p-148-ts...ort-block.aspx
If it is pretty normal of a swap. And using much of the OEM parts, getting a complete drop out with accessories, wiring, pcm, etc. would give a leg up on parts and cost if you can use most of the parts that came with the drop out.
The parts are out there. But can be costly to buy peice by peice.. You have to look at your budget and weight the time spend chasing down parts and mix/matching them.
BC
