LS3 in 67 Camaro
Old Nov 13, 2011 | 09:07 PM
67LS3's Avatar
Default LS3 in 67 Camaro
My project is done and i would like to thank everybody on this forum that helped me. If anybody needs info on 1st gen camaro swaps let me know if i can help.
Attached Thumbnails LS3 in 67 Camaro-sdc10606.jpg   LS3 in 67 Camaro-sdc10607.jpg   LS3 in 67 Camaro-sdc10609.jpg   LS3 in 67 Camaro-sdc10610.jpg   LS3 in 67 Camaro-sdc10612.jpg
Old Nov 13, 2011 | 09:27 PM
CETAWS6's Avatar
Man/that's/tight./nice.
Old Nov 14, 2011 | 12:50 AM
bmf5150's Avatar
Looks great
Old Nov 14, 2011 | 05:55 AM
ONyX711's Avatar
Looks great man, I am in the early stages of my 68 ls3 swap. Do you have a write up of the combo you went with? Headers, mounts, harness etc? Id love to get more details on your set up
Old Nov 14, 2011 | 10:14 AM
drenner43's Avatar
looks great!!
Old Nov 14, 2011 | 11:35 AM
gjohnson's Avatar
Awesome man! I just sold my 240sx L33 swap and I'm planning on tackling at 1 gen camaro LSX swap for my next project. I'm with ONyX711, any info that you can provide would be a great help for my planning. How long have you owned the Camaro? I've been searching through craigslist for the past few days to get an idea of how much a shell will run me.
Old Nov 14, 2011 | 06:55 PM
67LS3's Avatar
I used the gmpp crate engine and harness. gmpp trans controller with 4l60e. s&p mounts and headers. turbo 400 crossmember with a cadillac cts-v pan. spectra fuel tank with the same problems everybody has with these tanks. Get a different tank unless they fixed the issues. I used the corvette fuel regulator/filter. Corvette accessories with a relocating kit for the ac compressor. Got that on ebay. Puts the ac on the top.
Old Nov 14, 2011 | 10:37 PM
LucasTxHVAC's Avatar
Did you opt for the long tube headers? If you did use long tube headers could you post up a pic from the side to see ground to header clearance?
Looks like it belongs there, nice job.
Old Nov 15, 2011 | 07:50 PM
67LS3's Avatar
the s&p headers are mid length. just a little longer than a shorty. awesome quality jet hot coated. i would recommend them. still look like new with no discoloration from heat.
Old Nov 15, 2011 | 11:41 PM
pairof69s's Avatar
how about some pics of the oil pan clearance....are the S&P mounts 1in setback or what...? appreciate the info
Old Nov 16, 2011 | 04:23 PM
nailbanger91's Avatar
Did you use the stock clip? If so do you know what engine stands were in the car 327 or 350? I'm putting a ls-2 in my 68 stock clip with s&p mounts and stainless work headers but they arent fitting very well. They hit the steering box and the idler arm.
Old Nov 16, 2011 | 06:51 PM
67LS3's Avatar
yes the stock subframe. the engine stands were for a smallblock. the 327 and 350 would be the same. bigblocks had different stands. i tried every exhaust manifold i could find but would not clear the steering box. thats why i used the s&p headers. there are very small differences in the actual motor mounts you can get. only about 3/8 to 1/2 inch.
Old Nov 16, 2011 | 09:44 PM
59 camaro's Avatar
looks great ay
Old Jun 9, 2014 | 05:07 PM
dcdman67's Avatar
Default Cold Air Intake?
Did you make this or buy this? I am at this stage and need to start working on getting an intake fitted.
Thanks in advance!
Dan
Old Jun 10, 2014 | 10:42 AM
Harris1's Avatar
Very nice build sweet car!
Old Jun 10, 2014 | 11:12 AM
Corey R.'s Avatar
What radiator and fan setup did you use?
Old Jun 10, 2014 | 11:44 AM
1989GTA's Avatar
I hope he answers as the thread is about 3 years old. As to the cold air intake I would use a 6" radius aluminum 4" elbow in place of the rubber elbow he has. Or find a rubber elbow with a larger radius. Air does not like to make turns and the bigger the radius the better for airflow. Looks like he has the room for it.
Old Jun 11, 2014 | 07:04 AM
astross89's Avatar
pics of how you mounted the radiator?
Old Jun 11, 2014 | 03:57 PM
dcdman67's Avatar
Thanks for the response guys. I am using an AutoRad radiator with dual fans.
Here is a pic of the engine compartment as it stands right now.
https://flic.kr/p/nWy64g
Old Jun 11, 2014 | 05:13 PM
astross89's Avatar
delete
