Source for a full GM vehicle schematic?
Old Nov 15, 2011 | 10:29 PM
cyamaha2007's Avatar
Default Source for a full GM vehicle schematic?
Source for a full vehicle schematic? Im buying a 2003 2500 silverado thats been wrecked. I need to find a full vehicle wiring diagram. I want to use most of the truck parts in the Articulating tractor im building. When i say most i mean the front diff, rear diff, motor, trans, tranfer case, and gauge cluster maybe even the radio. I know the pcm and bcm work together alot so making all this work together may be a pain. I dont even know if its fessable to remove the entire harness w/o cutting it up. I want all the components to be happy in the new vehicle. Thanks alot Chuck
Old Nov 16, 2011 | 07:07 AM
Jones'n's Avatar
alldatadiy.com
Old Nov 16, 2011 | 08:51 AM
tsnow678's Avatar
This will help with the pinouts and could also help track down what wires are what.
http://www.lt1swap.com/
You can also go to a local garage that is techno savvy and have them print you out a complete wiring harness schematic tip to tail. I actually have a wiring schematic for a 2003 Silverado 2500 6.0 if I can find it I can make you a copy.
Old Nov 16, 2011 | 08:03 PM
Thanks guys i got it started tonight good oil pressure no smoke but i couldnt let it run for more than a few seconds the radiator was distroyed letting trans fluid spray every where.
Old Jan 30, 2012 | 11:47 AM
jojomanx's Avatar
Originally Posted by tsnow678
this will help with the pinouts and could also help track down what wires are what.
you can also go to a local garage that is techno savvy and have them print you out a complete wiring harness schematic tip to tail. I actually have a wiring schematic for a 2003 silverado 2500 6.0 if i can find it i can make you a copy.
.great info
