LS1 Conversion, what is this pin?!?!
Old Nov 18, 2011 | 02:20 PM
Strokinit383's Avatar
Default LS1 Conversion, what is this pin?!?!
Ok guys and gals, I'm in the processing of wiring in the ls1 in my 94 camaro. I have ONE wire left on the engine bay harnesses! Its connector c101, pin J - purple/white. I've read that its the Starter Relay Coil Supply Voltage (V6 VIN K). What does this do/where does this go?
Thanks all!
Old Nov 18, 2011 | 03:12 PM
bjamick's Avatar
This goes to pin 85 on the starter relay.
Pin 86 will be to ground
Pin 30 will be all time 12V or Ign 12v
87A will go to starter solenoid.
