Cam recommendations wanted for LS1
I have nice LS1/4L60e that I'm going to mod slightly and put into a '55 Chevy convertible. The car will be a cruiser but I want it to have a bit of performance when I want to have a little fun. Will definitely always be running under 6k RPM.
Mod ideas:
- 243 heads: I have a really nice set on a 2008 5.3 with 20k miles.
- New valve springs and pushrods
- LS6 intake
- New LS2 timing chain
- New Oil pump
What cam would you recommend? I would like 350+RWHP and a fairly smooth idle.
Been considering an LS6 cam or a little more (suggestions wanted)
A TR224 looks like a great cam but probably a bit
lumpy.
Also, at what point will I need a higher Converter stall?
Anything else I need to consider?
Thanks in advance.
Good luck
for 350rwhp, any of the LS6, GM Hot Cam, TR224R or TR228R should get you there. Would not suggest anything bigger if just a cruiser. If you want some Lop for the old school sound. Try the Comp Thrumpr cam or one of the TR's with a smaller LSA (110-114).
With the 4L60E, you can also up the rear Gear 3.55 or 3.73 and still get fair mileage.
But a Tune is the key to putting all of this together.
