65 Nova Wagon Ignition
Old Nov 20, 2011 | 05:26 PM
silverado01's Avatar
Default 65 Nova Wagon Ignition
I just installed a 3.8L, out of a 01 camaro, into my 65 Nova Wagon. I pulled the entire engine and harness from the car. Which wire actually turns everything on? The car already had a resistor installed for the VAST. Is this the only wire that goes to the key?
When I hook up the battery, the guages turn on. The Airbag Light is blinking also. I was thinking nothing would come on until I figured out how to hook up a switch for the ignition. I do not have the original ignition switch.
What are the 2 column switches for? Anyone know what the black box is for?
Also, I do not have the BCM. From what I have read, I still should be able to run the car once I make a 50HZ signal module for the injectors?
Thanks for any help.
Attached Thumbnails 65 Nova Wagon Ignition-column-switch.jpg   65 Nova Wagon Ignition-shifter-switch.jpg   65 Nova Wagon Ignition-black-box.jpg
Old Nov 21, 2011 | 06:41 PM
99ssleeper's Avatar
Not familiar with the first two pics, but the 3rd with the black box is the daytime headlight controller. That's all I know, sorry I couldnt help more
Old Nov 21, 2011 | 07:47 PM
lizeec's Avatar
The second pic is your starter switch there is a little rod or small cable that activates the switch. The rod or cable comes from the key switch itself.
Old Nov 21, 2011 | 08:50 PM
psiconversion's Avatar
LS1Tech Sponsor
With regards to the VATs, you are correct. You dont need the resistor ignition key. You only need to make sure the PCM sees a 50Hz signal when the vehicle is cranking. There are modules for sale on EBAY that do this or you can make your own circuit with a 555 timer.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 23, 2011 | 05:48 PM
Thanks for all the help! Nice wagon 99ssleeper
Old Nov 23, 2011 | 06:12 PM
71403's Avatar
First pic is the high beam switch
