Need help with harness
Old Dec 6, 2011 | 11:37 PM
Nachol's Avatar
Default Need help with harness
Almost complete with converting my harness into a stand alone. My question is when removing the 02 oxygen sensor which one do I remove? Front or rear of catalytic sensors.
Old Dec 7, 2011 | 12:42 AM
i r teh noobz's Avatar
Rear.
Old Dec 7, 2011 | 09:29 AM
bczee's Avatar
Remove the Rear.. you well need or use the Front ones, which are closer to the Exhaust Ports of the engine.
Old Dec 7, 2011 | 08:44 PM
Nachol's Avatar
Thanks guys... So here is question # 2 The harness that came with my engine had the 02 plugs cut off. The diagram below show my setup of 02 wiring setup, what style of plug do I require? and does each 02 sensor require a pink wire? I ask because the color wire I ended up with are
Light green Qty:2
Green w/white Qty:2
Tan Qty: 2
Pluple Qty:1
Plurple w white Qty:1
Old Dec 8, 2011 | 02:46 PM
sdetweil's Avatar
green is front (bank x sensor 1)
purple is rear (bank x sensor 2)
Sam
Old Dec 8, 2011 | 03:35 PM
TomM's Avatar
Remove bank 2 sensor 1, and bank 2 sensor 2....
T,
