another Lsx mustang
Old Dec 7, 2011 | 07:36 PM
kevins2000LS1's Avatar
Default another Lsx mustang
Got a mint 93 4 banger coupe. Got the ls6 out of my camaro. Going to get a sumped tank, holley black pump, AJE frontend and transxmember. Probably run a Th350 with manual VB and 4000-4800 stall. How do I wire the alternator and starter? Also what size carb? And intake? Engine made 426 rwhp fuel injected with 30lb injectors. Kinda need little insight
Old Dec 7, 2011 | 10:44 PM
94'BLKBRD's Avatar
pictures...
Old Dec 7, 2011 | 11:05 PM
stewdy1's Avatar
Alt will need a 12 volt keyed source with a 470 ohm 1/2 watt resistor inline to cut the volts down if u don't do this alt make last a day then hook big wire up to battery
Old Dec 8, 2011 | 05:48 AM
I'll post pics as the build gets going
Old Dec 8, 2011 | 05:52 AM
So find a 12v keyed source run a wire with 470 ohm 1/2 watt resistor in line correct, this is for the small wire on alternator to turn it on correct?
Old Dec 8, 2011 | 06:40 PM
RATBOX's Avatar
You could do that, or you could spend $20 and have the alternator converted to a one wire.
