my 98 v6 camaro
first thing is we are both using ls6 intake can i just repin stock injector plugs or get adaptors? map sensor extension harness will also be needed for him to use my truck harness (one main reason he can use harness is he is running a 4l80e i sold him) if he uses camaro harnesss he is only going to mod it for his 6.0 4l80e swap into 96 impala ss . should i try to get the harness or not go through all this trouble or can i steer clear of all stock harnesses since im running a t56? help please
Ls6 intake+ Truck harness= ev1 injector plugs. Not hard to install. Use heat shrink in splices.
Harness isn't that hard to work and this site has a good walk thru.
I gave around 30 for my injector plugs.
If you go t-56 make sure the 6.0 has the short crank, I think 01+ models if not you'll have to use a different crank or get that one worked.
