12v hot in run/crank
Old Jan 3, 2012 | 08:25 AM
99ssleeper's Avatar
Originally Posted by usafws6
i just checked again there isnt a wire that is hot in only run/crank. my only option is a switch i suppose.
There should be a wire that goes out to the ballast resistor on a non HEI setup. In my car I had to use this wire, however, I unpinned it from the factory harness and replaced it with a regular wire becasue it is a resistance wire. You will need a factory harness schematic and the wire should be easy to find.
