your 2 cents please
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
I pulled the harness back out (2nd time) and the guy that did the conversion took it home and worked on it, said that he found where he left out a pin that gives a run signal. Reinstalled harness 3 rd time, same problem.
My supplier hooked me up with a loaner pcm that he uses as a mule to get his rigs to a tuner with a dyno, same problem.
would one of the sensors failing cause the throttle to go dead after 3 or four actuation's.
