Circuit 439
Old Jan 2, 2012 | 09:27 PM
FakeSnake's Avatar
Default Circuit 439
Before anyone starts flaming me to do a search i have looked at many pinouts and they all pretty much say the same thing.
this is a 2002 5.3 PCM
here is the question, wire 20, orange on the C1 blue PCM connector is battery positive voltage, that means key on power to this wire. wire no. 19, pink, is ignition voltage, does this mean power to this wire only when cranking or all the time when key is on?
here is the pinout im referencing, its about 1/4 the down the page.
http://www.ls1truck.com/forums/elect...m-harness.html
Old Jan 2, 2012 | 09:38 PM
psiconversion's Avatar
LS1Tech Sponsor
'Battery Positive Voltage' means that it has power all the time. Ignition power has power with key 'On' and 'Cranking'. Hope that helps. I refrained from telling you to do research.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jan 2, 2012 | 10:03 PM
FakeSnake's Avatar
thanks
