Flex plate? ? ? What needs done
Old Jan 9, 2012 | 09:33 PM
Dj777717's Avatar
Default Flex plate? ? ? What needs done
Got a 2004 LS1 out of a vett that had a 6 sd manual sticking it in a gen 1 Firebird. Can one rework the original flex plate to work with a 200 4 auto transmutation? Or what are my options?
Old Jan 10, 2012 | 03:01 AM
chrisfrost's Avatar
Yes You need the flexplate/flywheel spacer and longer bolts and You need a flexplate from a 1997-2003 with automatic ,,,,,,,,it's easy to spot as it has a curve to it ( the flexplate that is ) and You can only install 5 tranny to engine bolts .
Old Jan 10, 2012 | 07:52 PM
S10xGN's Avatar
Haha! "transmutation", I like that...
Anyway, if we ASSume this "original" flexplate is not from the manual 'vette but from the 200R4's donor vehicle, then it's not likely to fit at all. I have this exact combination, I used a flat LS flexplate, the crank spacer, and 6 new (longer) bolts. It's been long enough ago that I no longer have the part numbers, but they are available on here using the search function.
