4l60e PwM ? for 5.3 conversion
Old Jan 15, 2012 | 11:13 AM
Dustytrix's Avatar
Default 4l60e PwM ? for 5.3 conversion
I have a 4l60e trans that I would like to use with a 5.3 conversion. What I can't understand is will this trans work with a 04 harness, computer and 5.3 engine. The number on the trans is 3WSD161C, the info I got means its a 93 model, 12 pin round connector on pass side. But the pump cover has PWM stamped on it and research I found says the pwm came out in 95? Anyway can I use this in a 5.3 conversion?
Thanks.
