SC400 lsx swap
Old Jan 15, 2012 | 06:24 PM
stackpoole's Avatar
Default SC400 lsx swap
I'm just needing some input. Wanna go with either a 4.8 or 5.3, 4l80, ?.
I want to eventually do a single turbo setup but thought I could hit with some spray right off the bat. That being said, what would you do? Could I run a stock lsx on spray. Would it be worth it or should I just dive right into the turbo swap? I've done some searching and I've seen guys doing this swap before but the threads are hit and miss. Not getting all the answers I need. What converter should I use, what driveshaft will work, ecu and wiring, H/C/I? Any input will be greatly appreciated. This will be a budget build. 4k or so spending limit. I do have a guy that can fab up the turbo kit and possibly the mounts/k member.
