Motor mount issue
Old Jan 27, 2012 | 08:08 PM
LSxChevelle's Avatar
Default Motor mount issue
So I took a spare block to see where it would sit with my mounts...
I have the $30 3/8" eBay plates and standard 350 mounts.
Issue is that when I bolted passenger side in the other can't set into place. The bolt hole in motor mount is up and out like 3/4".
Sorry for the crappy paint pic...
Old Jan 27, 2012 | 10:16 PM
bczee's Avatar
Are you talking about the long bolt that goes between the mount stand ? if so.. this is common.. you will need to shim the frame stands or the engine mount as needed. Another solution is to to move the Frame Stands and/or shim up if needed.
I movef my Frame stands by redrilling the holes in the Crossmember, i made the holes oblong in shape upwards about 1/4" to 3/8", then bolted down the frame stand again.
Just figure which way you need to move them.
BC
Old Jan 28, 2012 | 12:52 PM
BC
I'm thinking I will do same...just oblong the holes up for the frame stands. The mounts I have are the cheap Anchor brand and fit like crap. Had to grind a little, hammer, and force...
What mounts do you guys like? Energy Susp? Stock?
Old Jan 28, 2012 | 05:15 PM
garys 68's Avatar
2 swaps, both needed 1/4" spacers to reach the mount hole. I made aluminum between the adapter plate and motor mount.
Old Jan 28, 2012 | 06:45 PM
68BBChevelle's Avatar
Gary did you have to move your frame stands any to get your motor to fit. Reason i ask is someone before me welded mine to the frame.
Old Jan 28, 2012 | 09:05 PM
bczee's Avatar
I am using Energysuspension.. oblong the hole for the frame stand on both side, that way the engine will not shift over and still be centered.
Old Jan 29, 2012 | 01:02 AM
garys 68's Avatar
My 72 Olds had the chevelle frame mount holes drilled from the factory. I just bolted in the chevelle mounts.
