5.3L please help!
I pulled the plug on a 2008 all aluminum 5.3L removed from a 2008 H3 Hummer. I believe it has DOD and AFM.
I've got an LS2 intake, valley pan, injectors, and fuel rail. I believe I need to change out the lifters.
I'm planning on installing a TR220/220 .551 lift 112 LSA cam in it, but this DOD thing has me all screwed up.
Not sure if that cam will even work. I also plan on going with a custom harness, ECU tune, and etc. But again, not sure how this all plays into the DOD delete issue.
Could somebody please summarize what is needed to delete the DOD and AFM?
Cam phasers?
Will the Mast Motorsports pan work with this engine if the DOD is deleted?
Do I need to plug the AFM oil sprayer? Is there one?
Will I need to replace the oil pump which is high capacity I believe?
Does something need to happen with the reluctor wheel?
Timing sprockets need to be changed? The cam comes in single bolt and 3 bolt applications.
I'm not even sure whether or not this engine has VVT in additon to the DOD/AFM.
Crank sensor changes needed?
I plan to mate this to a manual transmission or 4L70E.
What a PITA! I should have researched first, but it was a good deal. This is why I was staying away from LS engines. So many variables.
I'm sure somebody knows something about this engine and I'm also sure somebody out there has done this delete.
Thanks in advance...
This motor does not have VVT. So there is not cam phaser.
Basically remove heads and change the AFM lifters. I would just change all the lifters to the LS3/LS7 units while you have the heads off.
The remove the intake and install the LS2 cover that has the orings to block the AFM ports in the block. The AFM valley cover will have the AFM stuff attached to it. You can reuse the oil pump shoudl be fine and the pan will bolt right up to the block.
Yeah, I'm still new to these newer engines .
The tuner should remove the AFM From the tune if it had it but like I said 95% sure the LH8 doesn't even have AFM.
