Vss?
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
You can get inline VSS as well. Form "Jags that run" google it.
But would help to know what year motor, trans and transfer case you have!
Haven't done this myself yet, but am in the process of.
You have 2 options, what they've listed above for the adapter.
OR switch to a newer case, they vss tone rings built into them.
Post up which case you have, and we can go from there.
The transfer case is NP205.
What about the differential-mounted ring? Do you guys know anything about these? They show it on the rear driveshaft yoke but couldn't it be mounted on the front yoke at the transfer case? Does the sensor care which way the reluctor turns?
The JTR differential mounted reluctor/VSS is for an S10 diff, dont know if it will work on a 10 or 12 bolt.
If you only have a mechanical speedo output, Dakota Digital makes a pass thru VSS that connects to the speedo output. It will provide the signal the ecu needs to preventing stalling issues. You can have the ecu retuned to read the DD VSS PPM count correctly but doesn't make any difference.
http://www.youtube.com/watch?v=QFVOcBuZfb8
With some fab skills you CAN adapt an NP241 output shaft tone ring onto an NP205:
http://www.pirate4x4.com/forum/showt...=770136&page=2
Or the Jags that Run cable to electric adapter will also work. I have a new one for sale that I never used if someone wants it.
