Oil system priming help please
My set up is a Moroso pan and I modded the pickup tube for it and made sure it didn't leak. I am running a remote filter set up with 5/8 tubing going to it. I pulled both tubes off to see if oil was making it that far and it wasn't. I pulled the spark plugs out to get some more RPM out of the starter and still did not have oil.
What methods are y'all using to prime your motors? Am I missing something concerning the way I am doing it? Ive read on the forum people were turning it over 4 times and getting oil pressure indication.
Thanks
Also fill the oil filter before cranking. In your case you could even elevate the remote filters when filling so oil works its way back into the motor.
I'm wondering why people have different results?
http://www.carcraft.com/techarticles...d/viewall.html
this is a pretty good article
gonna have to try this on my build
