6.0l wiring harness question..
C2 plug - Wire color - Description
F11 - yellow - Transmission mounted neutral safety switch output
F9 - pink - fused ignition positive voltage
E3 - light green - Transmission mounted neutral safety switch output-park
A9 - light green - back-up lamp feed(pretty sure i know where this one will go)
F10 - purple/white - starter relay feed- coil
Also on this same plug their is a pink wire that goes from pin F2 to the C100 pin C. What do i need to do with this wire?
