Anyone using solid engine & frame mounts for their swap?
Old Feb 13, 2012 | 09:40 PM
LS1 pwrd NOVA's Avatar
Default Anyone using solid engine & frame mounts for their swap?
Before i make any mounts or buy any just wondering if anyone used pure solid mounts? No rubber or poly pads. I have some solid mounts so i can decide what to do?
Old Feb 13, 2012 | 09:54 PM
2165 Turbo Rail's Avatar
i did no issues
Old Feb 14, 2012 | 07:13 AM
Would you happen to have a pic of your setup?
Old Feb 14, 2012 | 07:16 AM
If I do it would be in my build threade. ( link in my sig)
Old Feb 14, 2012 | 11:38 AM
borrone821's Avatar
I'm using solid mounts in my 69 GTO... dirty dingo sliders.
I'll post a pic when I get a chance
Old Feb 14, 2012 | 05:47 PM
I am gonna go solid front and rears, when I get that far...still doing t56 conversion and locating header/oil pan combo.
Old Feb 15, 2012 | 11:27 AM
STEEPSS's Avatar
Biggest problem is the transmission of vibrations throughout the chassis. Has a tendency to reverberate and drone at certain RPM. I'd go with a poly setup. You can make the plates for the motor, and then use something like this
http://suspension.com/4-bar.htm
And then weld that to your frame / k member or whatever.
my .02
Old Feb 15, 2012 | 12:19 PM
garys 68's Avatar
Solid motor mounts, rubber trans mount. You can expect more noise, vibration, etc. But the 68 corvette convertible has sidepipes, so a little extra noise is no big deal.
