Looking for a short AC compressor
I need something shorter to make sure I don't have header or engine mount clearance problems.
I think the Sanden SD508 might work fine, but figured I'd see if there were better options.
Anyway, if you're using accessories with the Corvette spacing, consider the LSA compressor add-on kit. I think it works with the Corvette spacing. It looks tiny compared to the other LS compressors!
I guess the main thing would be from the middle of the belt groove to the back of the compressor...
It looks like the LSA mounting bracket mounts similar to the C6 ac bracket. Maybe a pic or 2 if you can
Thanks
