g body vss help please
Old Mar 8, 2012 | 08:30 AM
V666's Avatar
Default g body vss help please
Forgive me if I missed it in my search. Does anyone make a inline vss theat will run off my speedo cable. I only need the vss for the ecu not the speedo. Thanks in advance
Old Mar 8, 2012 | 08:47 AM
garys 68's Avatar
Dakota Digital
Old Mar 8, 2012 | 12:32 PM
tta656's Avatar
http://www.transmissioncenter.net/sp...n_______va.htm
Old Mar 9, 2012 | 08:21 AM
Dothedew's Avatar
ECM will need to be programmed to accept that signal. You'll need to know your tire size, rear gear, and speedo drive and driven gears for them to tune properly.
Old Mar 9, 2012 | 08:55 AM
garys 68's Avatar
Actually, the Dakota digital will only read about 3 mph with a non-programmed ecu, but it will stull resolve the stalling issues. If you reprogram so that the ecu is reading speed accurately it works too, but will not provide a stable enough signal to run DBW cruise control.
Old Mar 9, 2012 | 04:46 PM
V666's Avatar
thank you so much. looks like im gonna get one. I just need it to signal the ecu so it can have decent street manors (well as good as a pt-88 turbo'd street car can have)
