PCV fresh air connection help
Should I just stab a connection in the intake elbow after the MAF sensor? Could I put it where the EGR would connect to the intake?
To be honest, I have a hard time understanding this whole setup. Lets say I plumb it to the intake elbow. It seems to me that if air is being drawn into the intake by the motor that putting a connection at this spot would draw air out of the passenger valve cover, not allow air in to the passenger valve cover. I would appreciate anyone who can describe how this works. (I know it ends up at the top of the intake after going thru the engine)
You would not be able to use the EGR port. That would create a vacumn and not fresh air. That is why it has to be post MAF but before the Throttle body.. unless you have port on the TB for Fresh air.. (see a OEM one, you will see that the port is just a passthru and not on the Vacumn side.
BC
