Rewiring a DBW harness..
Old Mar 24, 2012 | 07:20 AM
Old Geezer's Avatar
Question Rewiring a DBW harness..
NE1 found a way to rewire a truck TAC and foot pedal to work with the Vette throttle body??
I am looking to use an 05 truck pedal/TAC with an 03 Vette t/b. [The Vette TAC modules have been discontinued by GM.]
Any help is appreciated!
Old Mar 24, 2012 | 10:24 AM
99VetteFRC's Avatar
I can get you some schematics to compare with. I don't know if use the same resistances in the pedals. You should check the values before considering this.
Old Mar 24, 2012 | 04:01 PM
Old Geezer's Avatar
Thanks! We have the schematics, and are looking at the values....We have done scans on the resistors and looked at their hi/lo wiring positions. Nothing concluded as to what we may/may not change to get this to work....
We are now looking at the other input[s] to the pcm, that may be needed for it to work..
More later.........
Old Mar 24, 2012 | 07:08 PM
99VetteFRC's Avatar
You could always use a truck TB right?
Old Mar 25, 2012 | 07:39 AM
70lsgto's Avatar
Default vette tb
Im using an 04 truck pedal to control a 05 vette ls2 using a tac box from speartech, but the guy that set it up on the dyno had to do some programming to make it work, hope this helps.
Old Mar 26, 2012 | 06:49 AM
Old Geezer's Avatar
Talking Thanks!
We've scanned all the resistances and have made a chart of such.
The LS2 t/b is next on the schedule..Seems some Vette guys are making that swap.
