LS1 alternator connector wiring question.
Old Mar 26, 2012 | 06:27 PM
Dr Poofist's Avatar
Default LS1 alternator connector wiring question.
Ok I know I need to wire the "L" terminal of the 4 wire alternator connector up to the dash dummy light. BUT... The connector I got new from GM is labeled from drivers side to passengers A B C D.
My question is which terminal is the "L" terminal.
Many thanks in advance.
Dylan
Old Mar 26, 2012 | 07:39 PM
TS99SS147's Avatar
S F L P. S is the 10 ga.?(largest) wire that goes to ignition then the F(field) then L which is the one for the light circuit. Sometimes the alternator is marked on the regulator.
Old Mar 26, 2012 | 07:51 PM
S10xGN's Avatar
See if this helps:
Attached Thumbnails LS1 alternator connector wiring question.-alternator.jpg
Old Mar 26, 2012 | 09:43 PM
Dr Poofist's Avatar
OK so "L" is the third one over from the drivers side?
Old Mar 27, 2012 | 03:41 PM
Dr Poofist's Avatar
*crickets*
Old Mar 27, 2012 | 07:57 PM
S10xGN's Avatar
Dude, just look at the connector pic in the lower RH corner and compare it to yours. It's not rocket science, the connector only fits one way.
Old Apr 26, 2012 | 03:08 PM
cruisin'73's Avatar
Default Thanks!
S10, awesome diagram. I am getting ready to integrate my carb'd 5.3 into my Nova and was looking for an explaination on the alternator wiring. Pretty simple really, thanks for the info!
